Advantage
Active Member
Hey, I have an issue and hoping you could point me in the right direction. I have DPH-A drives mated to D6-350's. The issue is on the starboard-side trim. When I enter "beach-mode", it seems to be blowing the trim relays both up and down. This has happened twice.
I replaced the relays and it initially worked but my finger slipped off the helm-station trim button while it was still in beach mode. i tried it again and it then stopped working. I suspect the relays are blown again but I didn't have another set to test. What do you think my problem could be?
Also, it should be noted that the trim worked just fine when operating in normal ranges with no blown relays. Seems to only be an issue when entering beach mode.
Thanks in advance for your help.
