johnnys
Active Member
Hi all, boat lifted on Friday and the dreaded pink skin fitting was obvious on one of five that are fitted below the water line in close proximity to each other. I am assured by the manufacturer that all fittings and valves are DZR but there is no hull anode, we have a sail drive with its own. Obviously I will change the affected ones but my question is: do you think an anode fitted nearby will help and if so is there a correct way of wiring it to five skin fittings i.e. in parallel.
Thanks in anticipation John
