Dezincified Blakes seacock? Advice on condition please.
differentroads
16 Apr 2012
Mediterranean
blog.offbeatsadventures.com
Hi. I have four Blakes seacocks which will be around 40 years old. All work fine, especially after regrinding the valves two years ago.
But after sharing a photo of them on a PBO forum thread, its been pointed out how pink one looks and that it might be badly dezincified (thanks ctva).
Here's the original photo plus another where the light shows that the valve isn't as alarmingly pink as the close up. But still rather pink and striated. I can't remember the look of the other valves but assume they'd be similar or I'd have been more alert to a potential serious problem.
I also serviced another Blakes that was only four years old. Haven't got a photo of the valve, but the colour of the body is noticeably more golden.
I'll be taking the boat out of the water next winter and will disassemble the seacocks and check the through-hull parts and bolts. In the meantime, any points and advice gladly welcomed
The pink looking one is not dezincification, it is bronze. What Americans call 'red brass'. Blakes changed over from bronze to DZR in about 1985, so your recent yellow looking one is DZR brass. See my website for lots more info.
Thanks for that reassurance. I think I panicked myself slightly by comparing photos in retrospect, not knowing that Blakes had changed to DZR brass ☺️
Your website is great, by the way. I've visited a fair few times over the past few years of my refit and really apprecited the depth of knowledge and experience you've taken time to share.
Has anyone here ever experienced a catastrophic failure (as opposed to a leak) of a traditional Blake's seacock due to de-zincification?
I mean the sort of failure where the seacock breaks up.
Very rare to see a blakes seacock really breaking down. vyv is absolutely right. Neither of the photos give rise for concern. What you are looking at is the plug. In other words the moving part. The fixed part attached to the hull is the part that would give concern if corroded. Clean up the part you see on the outside of the hull. If this is pitted or very "pink" replace it but its rare to see this on a blakes seacock. Lapping the plug to the housing with grinding paste should remove all surface discolouration then reassemble with waterproof grease. A tube of proper Blakes seacock grease is a wise investment. I have a tube I bought in 1976 and its still going strong!
