pugwash
Bought a 30-year-old wooden boat a couple of years ago and on gentle shakedown cruises close to home noticed by simple checks (transits by eye) etc that there didn't seem to be much in way of deviation. (Yes, I KNOW I should have checked properly but there you go, I didn't get round to it).
When I picked up a hand-held GPS to carry as an auxiliary to the main system I used it to check the compass. I steered a close course for two or three minutes to give the satellites time to see where I was tracking, then checked the compass against the GPS; it was slack water with no tide or current discernible. I boxed the compass in 15-deg increments and found at most two degrees of deviation, alll under power, so that leaves possible differences when heeling. For practical purposes the deviation was small enough to be disregarded. Great.
The other day, however, I found an old deviation graph for the boat made by a previous owner and the figures were substantially higher, about ten degrees on some courses. A new engine has been fitted since then but of course it's in the same place.
I can check again in the recomended way using a hand-bearing compass away from the engine and also lining up on transits, but I'd like to know whether my check was in fact water-tight. Did I make a basic error?
