Dessalator D60 Water Maker Problem?
goeasy123
10 Nov 2018
When I turn the lever on the side of the filter mount to flush no flushing water goes through the systems. When I start the water maker immediately a fitting in the low pressure circuit blows of..... for example the soft plastic screw in fitting that holds the electrodes for the produced water quality sensor.
Before I start pulling things apart does anyone know what might be wrong?
I suspect a blockage in the feed pump pipes. Probably after the fresh water flush joint. That would explain also why you cannot flush.
