Depth transducer
mireland
26 Apr 2004
Thames valley, UK
I am fitting anew NASA Clipper depth to a steel hull 6mm thick. So far as I can see it is intended to be mounted inside the hull. Will this work through a steel hull?
FullCircle
19 Nov 2003
are you sure John?, you seem as bit hesitant and wishy washy in your answer today.
Jim
<hr width=100% size=1>Jeanneau 35 - only 13,272 lbs displacement, not even 6 tons,what a lightweight!!!
milltech
31 May 2001
Worcester
www.iTalkFM.com
This is what I assume you must do, but take expert advice, I am not expert at anything except wasting time, which is why I'm here.
You build up a steel fairing to go outside, welded the hull, to protect the transducer from impact damage, so that only the bottom face of the transducer is open to the sea. Then drill a hole in the boat large enough for the transducer stem and poke it and the cable in from the outside, pull it up, use a bit of sealant, and then screw down the nut.
<hr width=100% size=1>John
http://www.on-line-marine.com
milltech
31 May 2001
Worcester
www.iTalkFM.com
There is only the one! Of that I am sure, it just has to be used in the manner that suits the installation.
