Neddie_Seagoon
When underway my depth sounder rapidly and erratically cycles through readings - I have learned that the deepest reading it gives is probably right, but I assume that the tranducer is not adequately mounted - it is stuck to the inside of the hull in a glassed-in oil bath. At first assumed that there was a lack of oil - but there is plenty. While it is stuck to the hull it can be wobbled a bit - so it's not as stuck as it might be. I thought about pulling it free and suspending it in the oil bath, but before I do that I thought I'd ask for suggestions. I have only used it under motor so far - could the problem be electrical interference (no evidence on other devices such as radio)? Going slowly (3 knots) in calmer water it is more stable, going faster (6 knots) in open water it is totally erratic. It is mounted in the bow a little ahead of the keel.
Any thoughts?
Ta,
Steve
Any thoughts?
Ta,
Steve
