steve yates
Mytransducer wasnt working, I epoxied in the tube to the hull, added some olive oil and pit the transducer in. Initially it was giving me fluctiating readings, playing around I realised it did that if I pushed it all the way down till it was hard against the hull, whereas if I held it up a bit, it gave me correct readings.. So I set it so it floated in the oil a bit above the hull surface, and everything was working fine. I left it running all afternoon and by evening noticed the numbers had vanished, then they reappeared, then vanished, then reappeared and vanished again. They reappear with a consistent depth but having them vanish would be very disconcerting in use.
Any ideas what I should be looking for?
