Lahara
I'm replacing my old B&G depth sounder which has a through-hull transponder with a new Furuno model having an in-hull transponder. The new transponder is fitted into an Airmar (P79) base attached to the inside of the hull and is set down into a fluid bath contained in the base.
For the fluid, Airmar recommend using propylene glycol or mineral oil, with the former seeming to be their preferred choice. I understand propylene glycol is, or is the major consituent of, antifreeze fluid for use in radiators of water-cooled engines. Though I could probably buy antifreeze fluid locally in the city, I'd prefer not to start using it as all my cruising is done in Brisbane and points north - i.e. in the tropics. It seems to me that if I ever needed to top up the reservoir of fluid, say at Thursday Island (at the northern tip of Australia), antifreeze may be difficult to obtain from shops set in amongst the palm trees.
I appreciate the purpose of the fluid bath is to provide a constant acoustic path between the transponder and the hull by excluding air and I can also see that use of antifreeze fluid for boats operating in climates much colder than Australia makes a lot of sense. Having gleaned from diverse sources the use of olive oil, baby oil, castor oil, and even plain water, as the fluid in transponders installed by others, I was wondering what were the views of the wider YBW forum. Leaving aside its antifreeze characteristic, does propylene glycol have a particular property that makes it ideal acoustically? Is there a 'mineral oil' that has similar properties? Or to put this another way, if I'm not intending to use antifreeze, what is the best mineral oil to use as transponder fluid, and why?
