glsg91
I have bought this year a Nexus (Silva) NX system which is delivered with a plastic rectractable thru-hull Airmar 200 Khz depth sensor with temperature sensor.
I have a sailing yacht of 10 meters. It is mounted on the same place of my previous Silva depht sensor.
Now I have a strange problem with the depth reading.
At some places the depth shown on the instrument is about twice the real depth (for example depth is really 4 meter but several times 8 meter is shown). This happens sometimes for a few seconds to a minute (sometimes longer). This not the case everywhere. It looks like it has someting to do with the depth and/or the kind of ground. I'am on the inland waterways inn the north of the Netherlands (Friesland).
I didn't cut off the cable lenght.
I tried a lot of things:
- another Nexus NX2 server (where the sensor is connected)
- use a seperate battery for the server with no other connections
- the cable through the boat without nearby other cables (interference)
- holding the sensor on a few different places inside the hull
- holding the sensor outside the boat in the water
With the last 2 it looks like it occured less but I'am not sure.
The local Nexus dealer cannot find any failure while testing. They also tell me that the sensor cannot be the problem.
The only solution is to sent the sensor and server to Nexus Sweden which will take more then a month (without a replacement). This I don't like of course.
Does anyone have a solution for my problem ?
Regards,
John Brattinga
Netherlands
Regards,
John Brattinga
Netherlands
