waterline
Can anyone help with their experience of installing a depth electronic instrument on a 22 foot trailer sailer.
I have considered installing an electronic depth instrument such as a NASA or (similar) on my new Jeanneau SUN 2000, but am unsure just how easy a task this would be. I would install the transducer and fitting kit inside the hull as I don't want to drill through the hull, and run the instrument directly from the 12 volt battery. This will be the only instrument on the boat. My main concerns are the size of the "cut out" I would have to remove from the vertical chosen cockpit position. This would typically be 67 x 87 mm which is quite a large area to cut out of the boat. If I do need to cut this square out to install the electronic display unit, what do I seal the edges of the fibreglass cut out with?
Does anyone know if there is a display unit that would require a smaller cut out, or is even surface mounted to minimise the installation work required. As stated above, I intend to just connect the display unit directly to the battery, but as the battery is being charged from the outboard when the engine is running, will I need a regulator of some sort to protect the display unit?
Any help would be much appreciated
