Delivery trip Ocean Village - Jersey on a VDV 20m
Imperial One
24 Feb 2010
Hampshire
As I sit here in the office looking out at another indifferent day, I though maybe you might be interested to see a day in the life of a Van der Valk dealer........
Her owner, Peter and I had took "Jersey Falcon", a Van der Valk 20m, from Ocean Village Marina in Southampton to her home berth in St Helier last Wednesday and thought you might like to see some photos of the trip.
We started off by fueling her up, stowing all loose articles and checking oil levels on Tuesday in preparation for an early start the next day. She had recently come to OVM from Holland where she had been for her winter service before being stored, as always, in their large heated winter storage facility.....Peter really looks after his boat!
Here is a photo of her being craned in at the yard just before cruising across to me in Southampton.
The day dawned a little gloomy but with light winds and a low coming in later in the afternoon all seemed god to go so we set of a little later than planned just after 08.30.
As we went past Fawley all was good and Red Jet zoomed by with a cheery wave from the skipper.
We cruised on towards Hurst and the Needles at a steady 21 knots enjoying a comfortable passage and even got a hello from the raggies!:encouragement:
All went well with the passage and we hardly saw any traffic apart from a few large ships in the mid channel. Some fisherman had put a string of pots down in 330 foot of water which was a bit of a surprise as was the rather large log floating half submerged in the same area. Luckily we saw both in good time but I do wonder what sort of damage a log that big could do to a planing GRP hull.
Then, as we got to the Alderney Race we had an engine overheat. Most convenient as the wind had got up to a F5, it was raining and a little lumpy in confused waters. I went to the engine room to discover that we had lost some coolant from no 1 engine. :ambivalence:
As it was shut down immediately the alarm went off, all was well and we continued on the remaining 3 anyway! This excitement later turned out to be a broken drive shaft in the water pump causing the impeller not to function and hence overheat and blow off the steam via the coolant filler cap....just a bit of a mess and a new pump then!
Apart from this irritation, our passage all went to plan and we were soon cruising past La Corbiere lighthouse and nearly home.
Jersey Coastguard were heard chatting to Condor Ferry which showed up on our system as traveling at 37.5 knot and looking very colourful as she went by.
The rain started to pelt down just as we arrived at St Helier and entered the Marina so putting out the fenders and warps was a somewhat damp exercise (for me anyway!).
No sooner had we moored up, the rain stopped, the sun came out and Jersey Falcon was home again safe and sound just in time for the Jersey Boat Show. Time for a sandwich and a coffee I think!
I have a few more photos if anybody is interested but I suspect these will be enough to give you a flavour of the day.
I hope you all enjoy the upcoming Bank Holiday and get out on the water if you can.
How many engines has this boat got? 4? Why? Just so that VDV could use IPS drives? How fuel efficient is 4 engines with IPS drives compared to 2 shaftdrive engines?
not very familiar with VDV 20m.... but from this I take it has 4 engines, not sure if that is impressive or slightly overly complicated on a 20M boat...? thanks for posting BTW
edited bit ...sorry, missed Deleted User's post on same subject!
I can't work it out to be honest. A typical 20m boat will need 2000-2500hp of shaftdrive power to reach 30kts so with IPS drives being available to a notional max of 1200hp, I can't understand why you wouldn't use 2 engines instead of 4. Having 4 engines sounds like a maintenance, control and monitoring nightmare IMHO, not to mention the noise
Hello Mike and Firefly, the answer is that at the time of building her she was to have 2 units but VP were not convinced that the larger IPS units were then stable enough.
(VDV are a build partner with VP and often get to try units before they are released.)
As a result, they re calculated everything with our engineers and came up with the suggestion of 4xIPS 600 (435 each) being the best all round solution. It certainly worked on this boat.
The owner says the boat is very economical at all speed ranges and she will do 28 knots loaded. She has a total of 1740 hp available and still has bags of space in the engine room. The engines are paired and one set of software controls them all without any fuss or bother at all. During our run to Jersey, I was perfectly able to speak in normal voice as the boat is amazingly quite. The engine room is fully aft and is very well sound proofed and as the exhausts are all under water this also helps keep noise to a minimum. FWIW the noise on FlyBe's Dash aircraft home was far in excess of the VDV at cruise speed. She is now 5 years old and has had no issues with software or anything else other than the blasted water pump drive shaft but that can happen to anyone I guess.
We do now fit 2 x IPS engines as they are now considered to be totally stable. Mr Van der Valks own boat has 2x1050 IPS D13 (800 hp each) although, of course, being a bespoke build, shaft drive is also available as an owner desires. That said most owners of our Alum boats are going the IPS route nowadays.
I have to say that the delight of the IPS units is not just in the economy they give but also in the close quarter handling of the boat using the joystick controls...........even I can get it right!!!:D
The second picture of Corbiere lighthouse, I hope it wasn't taken from the boat:confused:
Spot on, it was not. :encouragement:
The one I took on the day was somewhat clouded by the rain fall at the time so I used an old shot from my library....see below for how it actually looked on the day!
The photo was taken on my old Iphone, I must confess that I do wish I had remembered to pick up my SLR when I left home :redface-new: the photos would have been so much better altogether.
Yes a great engine room for sure. There are not many that you want to go into in a F5 while under way but being able to stand at full height does make it all the more bearable.
You are correct about the Racor's - 2 x engine and switchable of course, nothing to unusual there just easily accessed if needs be.
Somewhere, I have a photo of Dave Marsh in between the engines when he did his original test report on her. I have to say he looked quite lost in there!
No, not for the cocktails Firefly. :D
We always have a cocktailologist supplied with every boat just to take care of such mundane things as mixing drinks.:cool:
In order to save the forum going into meltdown trying to guess why it is there at all, I will come clean now - it's for auxiliary power if all four, sorry eight, filters get clogged up. You simply open the transom door and hang onto the swimming ladder on the bathing platform and off you go safely to home port. It is not quite as useful as IPS but it will get you home. :encouragement:
STOP PRESS:
Elf 'n saftee tell me to add a caveat to the post and advise wearing a life jacket in these circumstances.
.. but all that machinery, all on IPS, all in a lovely 20m boat... and a crappy 2.2 Suzuki o/b
That was my thought too. I have the exact same engine, and for a small dinghy on a 34' sailyboat it's spot-on. But I'd have thought whatever boat surrounds that engine-room would carry a much more impressive tender, with a correspondingly larger outboard.
indeed, bespoke little 4m rib with a nice 20hp Yamaha on the back would be more in keeping...or one of those hopeless williams jet ribs.. but there again it perhaps shows the owner is actually a real boat owner at heart.. I wonder if he also has a Avon redcrest to put it on?
There is a small dinghy folded up and stored in the removable aluminium tray the owner has had put on top of the engines, it just visible in the photo. It allows the tender to be taken out of the transom door onto the bathing platform for use and returned into the warmth of the Engine room for storage. We have installed a small air compressor in the engine room for inflating it.
As he cruises the Channel Islands and French Coastal area, he decided not to have a big rib or other "fun" tender this time round and reckons that this practical solution suits him very well.
His last boat which was also a VDV did have a RIB on the Bathing Platform but it hardly ever got used and just took up space. This boat does have cabling and a mounting place for a crane and also for a passerelle if any subsequent owner wishes to have a larger tender fitted.
FWIW, my ideal tender (on any boat big enough to carry it) would be a Boston Whaler Outrage..........as for engine HP, you can never have too much power can you?:)
My berth is 100 m away so I shall go and have a close look this weekend!
Go along and say hello.
Peter will be on board this weekend anyway and I know he is always willing to show people round and share a chat and who knows, maybe even a beer or a Cocktail if the mixologist is on board!!
Tell him Mike said so.
Cheaper to run than an equivalent shaft driven boat because of the virtues of the IPS engines economy.
The owner says he is very pleased with how little he is using.
I guess all things are relative, so many boats of all sizes seem to be getting very little use nowadays.
