Deflating Inflatables
nordic_ranger
6 Oct 2002
GREENOCK SCOTLAND
The electric pump manufactured by:
LVM Ltd.
AEROGEN HOUSE
OLDOAK CLOSE
ARLESEY
BEDS. SG15 6XD
TEL. 01462733336
FAX. 014627300466
Will almost suck a dingy inside out. great pump and they come with all the attchments and a very good after sales service.
ccscott49
7 Sep 2001
Just use your inflator pump connected back to front and suck the air out, works for me, mine goes back in the bag.
27 May 2002
I have been told not to overdo it with an electric pump otherwise the tube insides stick together and damage might result during later inflation.
True or False?
SailingDoc
4 Jan 2003
Portsmouth UK
I can't imagine the sides will stick together if perfectly dry. I was once advised to put some talcum powder into the tubes - when it's inflated turn the dinghy over a few times so that the powder coats the inside surfaces; should prevent them ever sticking together. I also put some on the outside when packing the dinghy away for the winter - same reason, stops the fabric sticking to itself.
Brian
snowleopard
Oxford
my pump has both 'suck' and 'blow' holes. i thought this meant i'd be able to get the ding really flat for stowage. i reckoned without the non-return valves: no air would come out so i was back to lying on it trying to squeeze in tn places at once. rats.
I have a inflator - de-inflator ... actually I have 2 ... one runs direct of 12v, the other rechargeable. I bought these in a camping shop.
12v was about 15 quid
Rechargeable was about 25 quid ....
Both suck that boat down to tighter / smaller than I can get it with pressing / folding etc. AND its quick once the bulk of air is out. You can watch the material actually crease / squeeze together !! Folding and getting into tight areas is then much easier ....
Oh the shop is in Tallinn ..... not UK !! But the LVM model etc. or the cheapies on the boat jumbles should do it ....
Nigel ...
Bilge Keelers get up further ! I only came - cos they said there was FREE Guinness !
You fix a thingy in the connector to press the vlave flap open ....
If its an avon - then trun the valve to lock open ..... if its Narwhal etc. older then unscrew the valve body etc. etc.
This should not defeat the average yottie !!!!
Nigel ...
Next time blow some french chalk into the tubes via the pump ..... a little goes a long way !!
Actually I'm joking - but there should be no reason not to !!
Having had a inflatable give out on seams ... old Narwhal .... I was surprised to see how wet the inside was, so would think that the inside would not be so prone to this as maybe suggested. I suck mine out often with the pump and I have not seen this happen .....
Nigel ...
