lw395
Just had a problem with my car.
Rear brake seems to have seized partly on.
Result very hot wheel and a bit of brake fade.
I.e. needed to pump the pedal slightly to stop.
I guess it got hot enough to either boil water that was in the fluid or boil the fluid itself?
The little plastic cap on the bleed nipple is melted.
Or I assume that lump of snot used to be a plastic cap.....
Is likely that the caliper seals are knackered? Does not seem to be leaking, but should I get a new caliper, new seals or what?
Looks like some grease has escaped from the rear hub, but not much.
I guess the fluid should be changed.
I hate cars sometimes.
Edit
B@@ger, how can I move this to the lounge?
Edit
