DHV90
Hi everyone, yet another paint question but would really appreciate some guidance
I will be pulling the boat out in a few months to do a comprehensive resto and want to recoat the deck and most interior surfaces to get the boat looking like new again. I am aiming for a smooth and maintenance free(ish) finish which is tough and hard wearing, which can also take an extra coat (for non slip on the decks).
This will be applied to bare fibreglass on the interior, so I would like to add micro ballons or some sort of filler to the coating to smooth out the finish (ideally, but not essential) then on the deck I will be sanding back through layers of paint, down to original textured gelcoat (polyester I assume) and ideally spraying on to this rather than taking all the deck back down to fibreglass.
I currently like the idea of gelcoat, keeping an original looking, thick finish that can be buffed and polished, but after extensive reading am a bit confused with the limitations and terminology of gel coats.
Firstly, am I right that gel coat is either polyester or epoxy 2 pack coating with tint added? and that epoxy will go over poly, but not the other way around?
What would be recommended for a sprayed finish in this situation, ideally using the same process inside and out? The deck will have hundreds of holes filled and damages repaired so needs a good waterproof sealing finish.
Current idea is to sand back, fill and fair (on the deck), then build up thin layers of epoxy gelcoat before a flowcoat layer on the top, and then sand areas down for non-slip and apply awlgrip or something similar. I know this will take a lot of patience and prep work etc. so not afraid of that. Are any 2 pack paints like polyurethane about that offer serious advantages over gelcoat? should I be worried about the UV longevity of the gel? Do i need to seal after the final layer or do anything else to stop the gel getting chalky?
Or alternatively, sand fill and fair, layer up some high build epoxy primer, and then use something like awlgrip over the top?
everything ive read seems to be very divided making it hard to work out what might work better.
thanks in advance! (sorry for the hundreds of questions!)
