Decent looking rocker switches - ideas pl's
Hmmm, switches off Maplins, bit of carfully laid up carbon, some nice dymo name tape, bit of aluminium sheet and a few pop rivets...job done!
If I can just pick this thread up and continue...
I am looking for some small, neat, surface mount switches, ie ones I can screw onto a bulkhead. What do I search for, surface mount seems to mean onto the surface of a circuit board?
Unfortunately that car would never pass current European type approval (high volume or low volume for those that know what i'm talking about!).... another bit of legislative idiocy, as it wouldn't pass, but then it would be perfectly legal to add them afterwards!!!! (which is what I suspect Zonda must have done)
panel switches!
Go to RS, and find the switches section, and then there are a series of filters that will let you home in on potential candidates.
RS have the best stock of any component supplier, but they are very expensive. I mentioned CPC, but Farnell are worth a look as well. They are both in the same group, Farnell have a larger stock, but CPC is often cheaper.
I'm putting more lights in and am looking for some decent looking rocker switches that don't look as if they were off a series one mini.
Any suggestions pl's/ websites etc
thanks
S.
Cockpit or cabin?
Cabin suggestions
white, space limited
http://www.tlc-direct.co.uk/Products/MKK4842.html
http://www.tlc-direct.co.uk/Products/MKK4841.html
if plenty of space, plenty of choice.
Mahogany
http://www.tlc-direct.co.uk/Products/VLXK1M.html
brass
http://www.tlc-direct.co.uk/Products/CM3712EB.html
and white easy to find andywhere.
If outside only one choice really IMHO - these make a super reliable inside choice too, definitely choose these if the switches are in the companionway or heads/shower.
http://www.boatelectricals.co.uk/sw...r-switch-contura-grey-dpdt-on---off---on.html
you can get these in black or white, or silver as here.
