Gordonmc
Advice sought.
A week ago I found a patch of discoloured mahogany on the saloon coaming. It is clear that rainwater has permeated into a corner joint through damaged canvas on the coachroof. /forums/images/graemlins/frown.gif since repaired.
The varnish (deks) came away with a fingernail and water exuded.
Last weekend was fairly dry and I was able to sand quite a bit of the discolouration off, but the wood still felt wet, but solid. There is about an inch x four inches of fibrous wood.
I realise the advice would normally be... cut out the rot and replace, but this is on a piece of solid mahogany 2 foot by five. There is no sign of damage inside the cabin.
What would be the best way to eliminate any spores before refinishing?
I now have the area covered to dry it out completely... one suggestion was to use wood hardener.
Comments welcome.
Comments welcome.
