Tdunbar
New Member
Thinking about a good way to help de-scale Honda BF45 cooling system.
Lower shaft into barrel of flushing solution.
Remove the thermostat and reconnect housing.
Attach flush adaptor.
Connect water pipe to the adaptor.
Install a water pump (drill powered) on pipe.
Other end of the pipe placed in the barrel.
Pump descaling solution from barrel into flush adaptor.
Water returns to barrel and is recirculated.
Run for 10 - 15 mins or more.
Flush with clean water.
Does this make sense?
