Shove
New Member
Hi
We are looking to fit a generator to our 45ft cruiser (bluewater sailing in mind). I'm only familiar with the conventional 230v AC types - 4.5kva etc. On visiting the boat show I understand Mastervolt, Onan & Northern Lights are amongst the best. I should point out that all 230V sockets and hard wired appliances will be supplied by a 2500kw inverter. (could be bigger as yet this is not fitted)
However I got chatting on the Fischer Panda stand and they suggest we consider fitting a 12/24v DC generator. I understand the theory is that as each appliance is utilised (for example: freezer, Hot water, AC sockets, hair dryers, charging etc) the Genny will auto start to keep the battery bank topped up to the required level for the inverter to work.
The positives being:
- lighter unit
- power on demand and not running unnessarily
- lower hours
- lower operating rpm
If you have any experience or thoughts on the above i'd really appreciate your advice /forums/images/graemlins/ooo.gif
Al
- lighter unit
- lower hours
Al
