Wardy
Like on a caravan, most of the boats i have been aboard have a foam mattress/seating placed on top of solid plywood (or similar) bases. In my limited experience of living in a caravan (soon to be a boat) this causes a lot of damp as any moisture tends to NOT escape as the system does not breath sufficiently.
Would it be a viable option when re-designing seating and berth areas to use slats of wood underneath the mattress, supporting the mattress and with an air gap underneath the slats leading out into the cabin (say about an inch deep) allowing a free flow of air underneaththe mattress? Or...
Is it the mattress (foam) that causes the damp build up and would it be better to just change to a different material make-up? If so, what is available?
I hope I have explained this query sufficiently
