Bigbang
New Member
Hello I had an incident where the rollers flips 90 degrees outwards when launching and the boat hit the pin twice causing two holes, I’ve seen on line I can repair with some chopped strand mat after cutting and sanding down, but I’m unsure what I should use as a final coat to seal, will using the resin as a final seal and then gel coating be enough? It’s below the waterline
