Ammonite
I have a 12v D400 wind gen that produces 5 to 6v when I spin it by hand on the bench, which is in line with the manual. I also get the same voltage where it links with the original duogen regulator and the same again at the fused battery connection. However, it is not registering any charge on the BM1 battery monitor despite being connected to the same negative terminal on the shunt that the solar panel is, which is registering on the monitor. The solar panel has a seperate Victron regulator. I've a multimeter and a clamp meter. Where should I start? Thanks.
