Seasick Ian
Active Member
Hi all, doing a service on my Tohatsu 8hp 2-stroke, and I noticed a build up of what looks like salt around the cylinder head gasket (decided against confirming with a taste-test). The engine is in salt water on a mud mooring year round. I have the tools and the service manual, so I will probably take the head off and inspect the water channels, but I don't have much experience, and was hoping to find some here, in terms of what i'm looking at. Does this look like salt weep? Is this normal?
I did a compression test, cold, and got 100 psi on both cylinders. The manual specifies 50 psi. I will get some bits and bobs to get the engine started and then take a warm reading. I'm not sure if the high compression could be connected to the suspect head gasket (would have expected low compression...).
Any thoughts on this would be appreciated,
Cheers
Cheers
