Ruffles
I'm replacing the woodwork on our old tender. I've bought myself a plug cutter / hole borer pair (made by Faithful) to make the roughly 50 plugs and screw holes required. Trouble is I'm finding the plug cutter hard to use. If I use a power drill it skitters over the surface of the wood and I often find that the plug is broken when I extract it from the cutter. It also gets very hot!
Am I doing something wrong?
Also, how deep should the c/s hole be to ensure the plugs don't fall out. The timber is only 3/4" thick but is likely to get worn.
