dolabriform
Hi all
I'm going to replace my Nasa Log with something better for a number of reasons, but the current hole is not big enough to take an Airmar DST800 which is my preferred option.
The yard have suggested that I file out the hole ( currently 41mm but needs to be 51mm), as a hole saw won't have anything to guide the central drill bit and will skip all over the place.
This is obviously going to be hard work, and so I thought about screwing a piece of half inch ply to the inside of the hull, to give something for the drill bit in the centre of the hole saw to work with. The boat is a Leisure 23 SL so the hull is quite ( very ) thick.
Any thoughts folks?
David
Any thoughts folks?
David
