Cutless bearing. - To change or not to change
Sorry to sound stupid but could someone explain what a cutlass bearing is? i assume its the bearing that the shaft sits in as it goes through the hull and into the gearbox?
I clearly am not technical but often peoples explinations here are better than i can find on google as they are less technical!
Quick Google
These are cutlass bearings
And this is where they go on the P Brackets
There is also one where the shaft passes through the hull (in or around the stern gland
Hope that helps
EDIT
And here's a photo of a guy having trouble getting one out!!!!
