burgundyben
I think I need to do a cutlass bearing, port engine stalled a couple of times going into gear, shaft seems tight to turn by hand, I haven't slackened off the coupling yet to check, but I suspect the cutlass bearing needs replacing, no idea when I last did them. I found invoices for 2 over the last 12 years.
Brass or phenolic resdin body, what are the pro's and con's?
Can I put a phenolic one in a bronze P bracket? Any benefit in doing so?
