Custom Made Mattresses
matthewriches
10 Jan 2016
Southwold & Ipswich
www.matthewriches.co.uk
Hi all, I had a new mattress for the master cabin a little while ago but was of low quality memory foam and whilst being used near enough every night certainly for the last 2 years, it has developed a nasty crater and is causing me no end of back trouble so time for another new one but of better quality this time! The guest cabin ones have lasted ok as only used a few times a month.
I have used https://www.marinebedding.co.uk for mattress dry mesh which worked well. Has anybody got firsthand experience on their actual mattresses? Or indeed, other company recommendations for a custom made shaped mattress? Hoping to get something sorted ASAP.
PaulRainbow
16 May 2016
Suffolk
Buy a good quality pocket spring mattress and modify it yourself. Not a hard job, mine arrives tomorrow, by coincidence.
mersey
29 Jan 2008
So what's the modification process, chop off the excess and sew in new side pieces?
I've never taken one apart, do you have any youtube or pictures of the process?
PaulRainbow
16 May 2016
Suffolk
Un-pick the side panel, remove springs, cut off the pockets where the springs used to be, trim the top and bottom covers and re-stitch the side panel.
Simple enough, especially in my case, i only need to snip a bit off of one corner. Probably take me an hour or so on Saturday morning.
mersey
29 Jan 2008
Okay cool, I've just 'got it', I was thinking of this:
But I see pocket sprung is this, and far more easily modifiable..
Hmmm, might do this, it's for a v-berth..
mersey
29 Jan 2008
How about a 6/8 inch memory foam mattress. Easily cut to the v berth shape?
Already got that, and have replaced once already, could easily just get it replaced again, but the lack of durability is the issue here, hence why the sprung mattress peaked my interest.
The v-berth foam set, that I've replaced already, is starting to sag in the middle..
richardabeattie
9 Jan 2004
Wiltshire
This will sound silly but I went to a mattress place on the Chichester - Emsworth road (forgotten its name) and they made me a proper pocket spring rectangular mattress which was 5 ft by 2ft. They looked puzzled because I am a six footer. But that size is not too big to handle and slides straight into the quarter berth. I make up the extra 12" at the foot end using sail bags or whatever comes to hand. Works fine and now I sleep. The only error I made was not specifying lifting handles on the sides.
smb
10 Jul 2002
Back in the UK & wondering why
+1 on the memory foam problem. One season (say 90 nights) and my backside was on the boards.
Reduced the back and hip ache a bit by sourcing a sheet of 1'' cheapish foam and putting that beneath the all singing/dancing 6'' marine special.
Pocket spring probably wont work for me due to access, so next time might just get bunk foam from eg anyfoam.co.uk, use the cover from the marine version and at 1/3rd the price regard it as a regular replacement item.
Does make me wonder if the marine environment is detrimental to memory foam, or will all these domestic 'mattress in a box' products be just as rubbish.
Steve
