driver0606
Hello,
In the late summer I posted regarding a leaking Sherwood raw water pump. There were a number of useful replies and I have now replaced pump shafts together with the latest seals on both engines. The age old lesson relearned was that just a few ours after one pump started leaking, the other engine started to do the same thing.
When doing the work I noticed a slight amount of "rock" in the drive belt idler pulley bearings. This is the older version drive belt system. They are both the same and bearings are smooth and quiet. The play is only about half to one millimetre at the pulley outer edges, but does not seem quite right. Are they standard ball bearings?
This may be one for Latestarter and any comments would be appreciated.
