Cummins 6BTA 370 hp
Aeghylon
13 Dec 2020
Hi All,
I have just joined the Forum that I found searching in the net for information about the subject engine. As you will understand from my english I am not mothertongue, I am Italian. Yesterday I have looked a typical Italian open cruiser, a Sarnico 43 equipped with a pair of 2005 6BTA 5.9 M3 with 500 hours. It kept 4 or 5 seconds to start and they were a bit smoky. The broker told me that it was cause were not started since October (due to covid restrictions the owner could not reach the boat) and due to the fact that outside it was cold. I would appreciate if anyone could share any information in these engines, are good ones? Any recurring defect?
Thanks a lot to anyone will share his knowledge.
Regards,
PowerYachtBlog
21 May 2007
Malta - Med Sea
www.poweryachtblog.com
Very good engine. precedes the QSD5.9 which is considered the most reliable engine in its size.
A bit of smoke at start is normal with a mechanical pump. If the smoke continues (5-10 mins the most) then I would revert to an independent technician to check the cause.
Really nice boat and well build. Good luck in the purchase.
markspark7
2 Nov 2014
Scarborough
Got the same engines in my boat , very reliable , tried and tested in many applications. Good fuel efficiency for a big lump , I have a engine manual if you need any specific information.
benjenbav
12 Aug 2004
I had Cummins 6BTA engines in a boat that I owned for 7 years during which time the only issue I had was a turbo hose coupling that failed. Mine were rated 210hp whereas 370 must be close to the upper end of where they took that block.
One of the big advantages back in the day was that these were basically truck engines for which parts were readily available and reasonably priced. They’re pretty long in the tooth now and I don’t know if that is still the case.
Bouba
6 Sep 2016
SoF
I didn’t want to be first to reply because I’m not a diesel expert but the 5.9 Cummins is the best engine in the world!
superheat6k
10 Jan 2012
South Coast
The Cummins 5.9 litre is the highest production volume diesel engine in the World. Originally as the 6BT at 210 HP the aftercooler took it to close to 300, so taking it to 370 is putting it on its mechanical limits. You do have to be careful that he cooling system is tip top at this rating.
They do not like overheating and my recent experience istestament to that, but I still love them, although I am happy to thrash my 210 HP all day long at WOT as the engine has so much spare strength.
If you want to know more then www.sbmar.com is full of information.
