Iain C
Quick one...if I am buying sheets for a cruising chute for a 32' boat, how long should they be roughly? Is there a "formula" as a %age of LOA for example? I don't want to buy ones so long it looks like a snake orgy in the cockpit...or worse, buy too short!
Boat is a Bav32, sheets will go from the clew down to the turning blocks on short strops on the aft mooring cleats, and then onto the winches which are right at the very back of the cockpit next to the wheel. I'll probably tend to inside gybe, although with a radar scanner on the front of the mast it might be nice to be able to outside gybe if needed. There's a short bowsprit of approx 700mm from the stemhead adding a bit to the LOA.
Thanks!
Thanks!
