BelleSerene
I gybe outside the forestay. Reduces the chances of a wrap. But Kemp Sails provide a pdf on the basics of cruising chute handling, which clearly describes running the chute sheets between forestay and sail, and gybing it on the inside. There must be a reason for this; and a way of avoiding the obvious wrap risk as you pull a wind-filled pocket of sail is pulled past the forestay. Can anyone help me out here?
Also, I wonder about a 'tacker': one of these devices you attach to the tack of an asymmetric which slides up and down the rolled-up genoa on the forestay. They're supposed to make the asymmetric work more effectively by stopping it pulling to leeward. But shouldn't you be letting out more sheet if it's pulling to leeward? Hell, when I'm at all down wind, the tack of my asymmetric heads up to windward if I loosen the sheet nicely! Presumably I'm missing a trick?
