cruising chute dimensions
gtuson
14 Feb 2002
Me and boat Llangwm, Pembrokehire
length from masthead to stemhead fitting is 11.2 metres. Would a cruising chute luff of 11.5 metres definitly be too long? Never used one so not sure how loose/taut luff needs to be...Any advice from experienced chute fliers would be appreciated...Also.. how does it work in relation to pulpit....inside/outside?
alandee
23 May 2006
Dorset.
Hi. If you go onto the Momentum Sails web site there is a PDF file that you can download with all the relevent dimensions on. No connection to the co. but their blurb is easy on the eye.
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
Chute flies outside of everything. I attach mine to a strop that runs from a cleat and up and under the bowroller. The chute is attached a few inches above the pulpit. On that basis the luff would be shorter than the forestay but obviously it is not pulled tight straight. Mine came with the boat so I haven't measured it but a sailmaker would know.
ytd
13 Jan 2005
Bav44 Sydney
Beacuse our rig is 7/8ths and the spin halyard is above the forestay, we were advised by sailmaker to get luff=forestay length. But by the time we added the strop at the tack and a snuffer at the head it's now a bit long. Still works well but can't come round closer than 90 deg to wind.
