Maf
New Member
Hi, I'm looking for advice from anyone who knows anything about this combination of boat and engine, please.
I bought a Cruisers International 224 last year and soon afterwards discovered that there had been a large amount of water gotten into the engine oil - the oil looked like double cream. A couple of different mechanics looked at it, and it seemed like a new engine was needed. I agreed with one mechanic to fit a NEW engine, with manifolds and risers. He said the water had got into the engine through the risers - probably because new gaskets weren't fitted to the risers when the engine had previously beed replaced, 5 years earlier.
It took him 5 months to complete this. I was given every excuse in the book why it wasn't ready. Completely missed all of last year, eventually getting the boat back at the end of September and finding that he had put a reconditioned engine in instead of a new one, as quoted for and agreed. I took the boat out to sea for an hour or so, and when I checked the oil, it had gone milky again. The mechanic came and took the 2 cylinder heads away (about a month after I complained) and said it may be a (head/exhaust?) gasket. After much more chasing the heads were put back on in January and he changed the oil a couple of times. He said he found a couple of burrs on the exhaust manifold that had maybe caused the leak (??) I ran the engine for 10 minutes on the pontoon, without taking the boat to sea, and on checking the oil - it was milky again.
He now tells me "there is a problem with the water level in the exhaust whilst the boat is afloat and engine is not running, causing it to back fill with water and into the engine." He says it is a "problem boat".
Is this possible? Surely there must be 100's, if not more, Cruisers International 224s out there. He seems to be saying that the engine is somehow too low in the boat and water is coming in through the exhaust because of it. Surely it's the same as any other boat set up like this?
He's sent me this photo of the water level in the exhaust cow, when he was working on the boat afloat.
Any advice gratefully received.
