tillergirl
Question for forumites here please
I spent a while yesterday crossing the Sunk Sand in the vicinity of the Barrow No 6. I have a fair bit of work to do to reduce the data to Chart Datum and all that but my preliminary calculations show that there is a flat bit 0.7nm NE of the old beacon from the Barrow No 6 on a track of approx 115/295 degrees true. Unfortunately there is no easy transit, for example between the Barrow No 6 and the Black Deep No 7. After a number of runs in the best place, I did also try a transit of lining up the western line of the Gunfleet Wind Farm (as per Christo2024's suggestion) and eeekk 'that were shallow'! In fact, there wasn't enough water but then that is half a mile further to the NE and really attempting to cross the Middle Sunk which is a bit daft. (Curiously the Windfarm lines are really difficult to see when lined up and in the sun!)
However there is this flat bit, about a tenth of a mile wide on a 115/295 track beginning or ending on the Barrow No 6 (which is in approx 18 metres of water at CD), well clear of the SW Sunk Beacon wreckage with about 1.4m least water at CD.
That seems to suggest that this is a settled weather 'half tide' crossing for most.
It will take a little while to crunch the data and draw up a chartlet (annoying SWMBO in t'process - 'Are you on that computer again?'). Question is chaps and chapesses, is this worth the effort? Or is this a bit too restrictive? Views please?
Mind you I'll probably do it anyway........
