christo2024
Its probably getting a bit late in the year now but I thought i would give you some info about crossing the Gunfleet below the Spitway in the vicinity of the Windfarm as I work there every day.
The Gunfleet dries on a LW Brightlingsea of about 1.0m between turbine A1 and A2. Good for Seal spotting.
Between A2 and A3 there is a distinct low way across, you will see us using it all the time. A good rule of thumb when heading SSE across the sand would be to go to the red Wallet buoy and head for turbine B3. ( I asssume you all know the turbine numbers). This will take you about 100m WSW of A3. Remember, 50m exclusion zone around each turbine for all vessels. Before you reach B3, depths will start to increase and you will be "across" the hump.
Regarding depths, we use the rungs visible on the ladder of every turbine. They are all at the same datum. Look closely at the vertical support either side of the ladder and with a tidal height of about 1.2m, the horizontal support for that vertical boat landing will come awash.
We get through the low way above with actual depth of 1.3m when there are 5 ladder rungs BELOW the horizontal support mentioned above.
Trying to cross further to the east has separate issues too much to discuss here.
Sold my beloved Nitebird now. But she is still around......
I hope you find this useful.
