Frontier
OK I need a bit of help here. I had a sort of incident, well and argument with another boat while returning up Chichester Harbour. If I am in the wrong then I apologise to the person concerned (if he is on here), but I don’t see what else I could have done.
So there I am cruising with the tide up the main Fairway, with boats moored on buoys on both sides and a boat coming down the fairway in the opposite direction.
All of a sudden a chap comes into view in a tiny tender (like an egg cup) rowing between two of the moored yachts on my starboard side looking as if he intended to cross the channel. He was about the length of my boat ahead when he came into view.
I thought “he will stop rowing,” I am a big mobo coming up and within a few feet of him and another boat is coming down, which he couldn’t possibly beat across the channel.
I instinctively eased off a little the moment I saw him and turned a bit to port, I couldn’t keep going to port or I would cross in front of the boat coming down. The rower hesitated for a second and then amazingly continued in front of me, which I simply couldn’t believe. I had to go astern with considerable power to stop and also continue bearing to port across the channel.
He then starts shouting saying “you were not going to stop were you” Well frankly no! He only appeared at the last moment and to stop would have and indeed did cause considerable action and distress on my part and those onboard. He then moaned about having right of way to cross the channel.
OK I am on weak ground now (well water I suppose /forums/images/graemlins/grin.gif) I was not sure if he had right of way or not. I tend to give way to everything in the harbour that is being rowed or sailed; I had just gone around or avoided about 50 yachts or more coming up the channel, giving way and getting many polite waves of thanks. (No I could see the smiling faces so they were not waves of disgruntlement before someone chips in with that. /forums/images/graemlins/grin.gif )
I simply can’t see how he can be justified to use rules against me, with the little distance he allowed, and he obviously intended to make the boat coming the other way stop as well. After me and the boat coming down there were not other boats in the channel. Why couldn’t he simply let us pass and then cross? It must be easier to just stop rowing for about 10 seconds than to make a 32ft mobo stop dead. It’s a bit like someone running out of a shop and straight across a pedestrian crossing, yes pedestrians have right of way but they also have a duty to use the crossing in a reasonable manner, one can’t be expected to know.
So why was he so amazed I was not going to stop, did he have right of way having left such little time for the other boats to see him and anticipate his actions.
I try to be a considerate mobo skipper and this has upset me a bit.
Comments appreciated, If I have got it wrong I will at least learn from it.
