pcatterall
[FONT=Times New Roman, serif]Hopefully my 2 pics will appear. These relate to my previous thread about my dripping shaft seal.[/FONT]
[FONT=Times New Roman, serif]Special thanks to vyv for his valued comments on this and for his great site.[/FONT]
[FONT=Times New Roman, serif]One pic shows the general arrangement of my Tides Marine seal and the other where the seal had been in ‘static contact’ with the shaft while overwintering afloat.[/FONT]
[FONT=Times New Roman, serif]I think it is a good example of ‘crevice corrosion’ ( though I suppose we could call it ‘contact corrosion’ ?) [/FONT]
[FONT=Times New Roman, serif]You can probably also see two patches of 'corrosion’ on the shaft but the cause of that is uncertain as the shaft was new and there were no 'splattering s’ of paint or other stuff on it.[/FONT]
[FONT=Times New Roman, serif]I guess that if I had used the engine with the seal running in the rough corrosion of the groove then the seal would not have lasted very long?[/FONT]
[FONT=Times New Roman, serif]As indicated in the early thread I was able to 'reposition’ the seal along the shaft and it is working fine however I need to find a solution otherwise I will be buying a new shaft every year or so!![/FONT]
[FONT=Times New Roman, serif]Is it the case that any lip seal unit like mine which is laid up in ‘Mediterranean’ water for the winter will be susceptible to this kind of corrosion?[/FONT]
[FONT=Times New Roman, serif]How frequently will the engine have to be run to keep the water oxygenated?[/FONT]
[FONT=Times New Roman, serif]Would another kind of seal be better ( like a PSS type) ?[/FONT]
[FONT=Times New Roman, serif]I note that the TM1 seal is only guaranteed for one year. Unlike the TM sureseal the whole unit has to replaced meaning lift out 'splitting the shaft’ and fitting another (£150) unit....potentially every year... sounds ridiculous to me. To be fair this seal has lasted 3 years to date but it is a worry that it only has the 12 month guarantee.[/FONT]
[FONT=Times New Roman, serif]I am going to get a replacement unit to have on board, should I just get another TM1, get a TM ‘sureseal’ with a spare seal to have ready on the shaft or get something completely different[/FONT]
