mick butterworth
http://www.theyachtmarket.com/boats_for_sale/1084291/?searchid=10966367&page=4 any explanation/ideas welcome
http://www.theyachtmarket.com/boats_for_sale/1084291/?searchid=10966367&page=4 any explanation/ideas welcome![]()
I wouldn't say it's crazy, but it looks steeper than most. Certainly more than the 15 degrees some have guessed at. If the crankshaft is parallel to the prop shaft, I wouldn't get away with it with my engine (which, FWIW, sits at 10 degrees compared to a permitted max of 15.)
Could be a Farymann engine with Hydraulic drive such that the engine can sit anywhere and installed horizontal.
I think jcorstorphine infers that the use of a hydraulic drive allows the shaft to be installed at an angle more divergent from the axis of the propshaft than would apply in more traditional arrangements, thereby allowing the engine to be sited further aft.Could be several other things as well, none of which I discounted. But isn't it the propshaft angle we're discussing rather than how it's spun?
I stand correctedHe may well have inferred that. He more likely implied it
But I'm not sure either necessarily explains the somewhat steep shaft angle. Surely one benefit of hydraulic drive, apart from giving flexibility in engine location, is that it allows similar flexibility in placing and orientating the shaft how you want. My take is that the OP isn't asking by what means the shaft can be engineered to work at this somewhat steep angle. He's asking why.
I'll certainly grant you that his somewhat minimal opening post allows other interpretations.
