NewbieNelson
So left my berth in Cardiff marina and managed to run into a bridge. No damage to the hull as the forestay took the hit which saved the mast from being damaged and we spun round rather than plowed through. I have bent my foil on the furling genoa so will need to find a replacement. It is too badly dented to get my genoa sail up the little track so I cannot use it. Any ideas on how to replace the foil on the forestay for a Halcyon 23? I believe I can release the forestay by easing pressure on the backstay by loosing the nuts whilst also rigging up a rope to tie to the anchor cleats and to the mast to hold the mast in place. Will I also need to detach the whole furling system from the top of the mast to drop the dented foil down so that I can remove and replace it? Any ideas on costs I could be facing?
