MagicalArmchair
I have been doing the unenviable job of removing my rusted mast truss from Triola.
http://www.ybw.com/forums/showthread.php?434586-Mast-truss-extraction-from-solid-Polyester-Resin
The force of the rusting truss expanding encased in the polyester resin coupled with the removal process has split the front of the keel and she was taking a dribble of water!! (which is the end game for this problem, and a problem our good friend and fellow forumite michael_w experienced first hand)
Normally with repairs, I would create a 12:1 bevel, and cut out 2 layers of fibreglass per mm of original layup using West system epoxy - but by jove, the hull is an inch thick here, that would mean to repair this one inch crack would mean creating a bevel of 24 inches in diameter and around 40 layers of fabric plus fairing epoxy on top. Is there an easier way? Grind back with a demel and fill with epoxy and colloidal silica? That just sounds like a recipe for it to pop out half way across the channel.
Edit: Looking at an old post on here, I found a broken link from VicS to what I think was this document: http://www.bluemoment.com/downloads/grp_repair_manual.pdf. This offers an alternative to a bonkers 24 inch hole in the front of my keel:
A better idea?
A better idea?
