Capt_Scarlet
I have a second-hand Yanmar 2GM20 which has suffered from water in one of the bores. I needed to have a new valve-seat and new valves fitted, and was hoping that was it. I was about to put it back together, when I noticed that the block had previously been drilled and tapped with overlapping studding between the offending bore and the water jacket, with some small tracks across the repair. Not qute sure what to do now....
I could put the sod back together, and hope that a new head gasket can cope. Probably the triumph of hope over experience....
I could try to get an engine repairer to have another go at the crack repair. Is there some high-tech fix for cast iron now?
I could try to get a replacement block - I suspect this is the best but I dread to think of the cost of a new one.
Has anyone else had the same dilemma?
Thank you.
Thank you.
