We are looking at a Super Seal 26 (Baker built hull #58). We were going to use this smaller yacht while we work on a long term steel project. However we found some cracks in the hull on our last inspection and are not sure how to interpret these. Some photos are to be found on the following page:
http://groups.msn.com/projectyacht/superseal26bakerbuilt.msnw
The craks are in the forward section of the hull close but quite at the bottom. They are one continuous crack that runs for over one meter on each side (port & starboard) of the hull. There is no surface displacement inside or out and the crack is not visible from outside.
There is also a crack in the centerboard well (see photos) and it look like it has been repaired in the past with the crack now in the repair. The yacht has a ballasted hull and a lift keel without ballast.
We are new to GRP and have no idea of the implications of the cracks to the integrity of the boat. The boat is located a long way inland away from the water so getting a marine surveyor to look at it is out of the question.
If anyone can shed some light on the subject it would be much appreciated.
