tillergirl
Back with the keel bolts today. Everything going fine until No 5, when on tightening, nasty sounds of wood compressing were heard when little effort was being put on the socket arm. A bit of a closer inspection suggests the wooden floor is not quite as hard as it was or should be. So out with the bolt again and reflection on renewing it! Just move the water and fuel tanks and hope I can wriggle it out from until the bunk furniture. As far as I can see it is only fastened by the bolt (which is out again) and presumably screwed through the planks. Then all I need is a bit of oak 5ft x 7" x 3"......
Gloom has descended upon me.
At least I can use a smiley or should it be a gloomy /forums/images/graemlins/frown.gif
