could changing outboard to 5hp from 2hp cause low revs
tcm
11 Jan 2002
Caribbean at the moment
Re: eh?
erm, get a farily powerful car and put some shopping in it - oh dear - car almost grunts and groans! unlikely.
Whatever is causing low revs, it ain't the difference between a 2 and 5hp outboard. Or, if you're planning on doing this, it should be fine!
omega2
17 Oct 2002
Essex Bradwell UK
Re: eh?
Have you got boost pressure gauges fitted? if yes then try to get them as even as possible, if not I would suggest you get some fitted as they will allow to balance the power output of the engines far more accurately than the rev counters, on most twin engine set ups neither engine will hit max revs when running alone as the props are built to be running together and both engines producing equal power. Talk to Paul Williams at Clements Marine 01234 378814. or sales@clementsmarine.co.uk. I have no connection with this firm but I have complete trust in them
