Squeaky
Good morning:
A friend has removed his rudder to change the bearing and discovered that the bronze stock is corroded for several inches above where it disappears into the rudder. The yacht is an Allied Sea Wind built in the mid-seventies.
It appeared that the diameter has been reduced by 3 or 4 mm over several inches.
The question is what should be done. It has been suggested that an inch of two of the rudder material should be removed to see if the corrosion extends down into the rudder and if not that the affected area be ground back to bare metal and then built up with welding/brazing (what ever the procedure is called) and then "faired" as well as possible because it will not be possible to put the rudder on a lathe.
Any suggestions/comments welcome.
Squeaky
Squeaky
