losangeles10
I’ve had my Cranchi 33 since new, 20 years ago. 6 months in commission and 6 months hard standing. Anodes always last the time but naturally, replaced every year. Same marina berth for over 10 years. Last year just before lifting out, the Marina stripped out the old bollards and installed new ones with all new wiring and water. This year after 5 weeks in the water anodes 90% gone, shaft on one outdrive failed and a great deal of corrosion. Insurers instructed electrician who could find no fault with the boat, (tested on the hard and also temporarily re floated). The boat has not been connected to shore power. The electrician is not being paid to find any fault in the marina but he did check with his reference cell between the water and earth and got a reading of 425mV and says there is a problem somewhere. He checked the bollard at the end of the line which actually had no earth connection at all! He checked the continuity of the earth between my bollard and the next one along and got a reading of 62,000 ohms. Given I’m not connected to shore power could this nevertheless be the cause of the corrosion? Marina seem to be lacking urgency in looking at this. Given we are talking electricity, salt water and the occasional diver down and we’ve all seen old cables drooping in the water I am surprised to say the least. The boat two doors along has suffered increased anode wear recently but thankfully no corrosion. They hauled out, replaced anodes and went back in. Boat next door says he has always used up anodes quite quickly. He’s attached to shore power but doesn’t know if he has a galvanic isolator and is not very clued up. In any event he’s been the neighbour for 3 years with no issue previously with our boat. I’m not an electrical engineer….is the earth issue a coincidental problem but unconnected? I’m generally not convinced by coincidences…usually means you just haven’t found the reason yet…!
