Zagato
I have looked at a couple of boats today that have long keels. On the nicer of the two (It's VERY nice
) there is a 5" long x 2mm wide split running length ways which is visible when you lift the floorboards, and bubbling rust around the top edges where the Ballast meets the GRP. Another smaller split goes port to starboard further back.
I believe ballast in some boats is iron which will corrode and I am really trying to find out the consequences and what would be involved to cure the problem. I suppose it could be surface water corroding it but unlikely or maybe a stress crack but then why the other crack runnig the opposite way.
If the keel has been compromised maybe by running aground, then salt water would fill the keel, once that has happened it's got to be game over surely as the ballast will gradually rust and eventually split/blow the keel.
What do you think, anyone got any experiance of this matter? Thanks.
