SvenH
My boat splashed this morning.
After starting the engine I opened the water inlet (sea water cooled) and almost immediately water came flooding out of the engine.
After some inspection I found a freeze cap had released.
The cap itself is clean except for some residue which I think is some kind of hard sealant.
But where the cap meets the block is very corroded, where I expected it more or less to be bare metal if the cap had been seated correctly.
Now a suggestion by a fellow sailor has me worried.
He mentioned a saildrive as a source for corrosion, which the boat has.
But more worryingly, I've had some welding done on the saildrive before the start of the previous season and after putting the boat on the hard I found more than expected corrosion on the sail drive, which I had repainted in 2 pac paint after welding.
( the welding was because of very old damage I discovered after buying in 2007)
The boat is sea water cooled and did not visit salt water since the welding.
Inner engine anode has not been checked yet but was fine at the start of last season.
Do any of you have experience you can share?
