Correct grease to stop corrosion
mulligan
Active Member
25 Oct 2001
Lincolnshire
Dear all,
I have recently had my mast Awl griped and now have to replace the track etc, unfortunatly due to the screws being St/St I have been advised to use a grease to stop a electrolythic reaction between metals, can anyone advise please as I am keen to minamise any corrosion.
Regards
Ross
You haven't said but I assume your mast is Aluminium; the stuff to use on the screws is Duralac, which is a yellow paste containing zinc bromate(or is it bromide? I forget). This will reduce the reaction between the mast and the screws.
cheers,
david
<hr width=100% size=1>Why'd he call me shortie?
Because you're small,...small,...S, M, all.
David,
You are correct, the mast is aluminium and the product you mention sound familiar, have you any idea where I might get this?
Cheers
Ross
Most boatyards and rigging shops will have it, and some chandlers.
cheers,
david
You will get Duralac, zinc chromite paste by post from [www.zsparsuk.com=link]here[/url]
A small tube will last for a long time. It is relatively inexpensive.
Iain
